hi all, i have TOM TOM mobile that is on my 6600 is there away of setting the volume to go through a hf8 handset , i can put calls through the handset but i can not receive the voice instructions from the tom tom
any help or advice would be helpful
IIRC, the Bluetooth on the 6600 cannot be shared between the GPS device and the headset, if it's a Bluetooth headset you are trying to use. If it's a wired one, it should work fine.
