Firmware Updater doesn't detect N73
5 replies · 3,918 views · Started 18 December 2006
I can't update my phone - I run Software Updater, connect the USB cable, select PC-Suite on the N73, click Next on Software Updater to detect phone. The NSU just sits there "Searching For Connected Phone".
PC Suite detects the phone straight away. I can open PC-Suite and close it while NSU is still searching, PC-Suite detects the phone straight away.
I've restarted the PC and the phone.
What else am I missing? Do I need some newer Drivers for the N73? I thought they installed with NFU...
Rack1600 wrote:I can't update my phone - I run Software Updater, connect the USB cable, select PC-Suite on the N73, click Next on Software Updater to detect phone. The NSU just sits there "Searching For Connected Phone".
Is your USB cable plugged in to your PC via a hub ? If so, try it in a slot that's connected directly to the mobo.
Failing that, try getting the latest version of NSU. It recently got updated to 1.2.0en. I have had no problems with NSU seeing my N73.
I only just downloaded NSU from Nokia, so i assume it's the latest. Also it's a direct USB connection to the motherboard - not a hub.
I'm going to uninstall and reinstall drivers for N73, and the NSU software (one at a time) and see what happens.
OK, I managed to get it to detect by waiting to connect the phone until the NSU was trying to detect - though i think I did that before, it worked now.
I can't get NSS to detect it though - should it detect the phone just over the USB by selecting PC Suite on the phone?
Rack1600 wrote:I can't get NSS to detect it though - should it detect the phone just over the USB by selecting PC Suite on the phone?
Yes.
