AnyBody experienced Virus with TomTom home download
2 replies · 3,371 views · Started 18 December 2006
Hi, has anybody experienced a Virus within tomtom home download from the tomtom website, Basically when you have downloaded it and then run it your computer shuts its self down !!!! ive tried doing a virus scan and showing all clear, well let me no if you have had the same problems as i have tried the exe and winzip file...
Brian
Its probably not meant to be run on the computer. Copy the files to your sd card and try it from your phone.
Hi, thanx for replying, its deafinately a p-c application, has anybody else tried it and it shuts down your computer, well you get a blue screen etc and hope this aint a problem as i realy want it,
The application you have on the phone itself is tomtom plus, but using tomtom home as follows http://www.tomtom.com/plus/service.php?ID=17
Regards from Brian
