tomtom plus question !!!
5 replies · 1,876 views · Started 18 December 2006
Hi does anybody no how to enable the WEP Key to be remembered every time you go to tomtom plus from your N80 ? most frustrating as having to type in 26 numbers/letters all the time !!, shame because using the wireless theres a default on there and it remembers.
Any comments Please
Brian
Hi, im not sure what you mean, all i no is that explorer and opera i have managed to log in successfully , and without re-tyoing my WEP Key, just that when i use tomtom plus on my n80 and via wlan, i have to put in my Wep key each time etc, hope ive explained ok and hope somebody can help..
Regards from brian
Mine doesn't even show up the lan's. When I search for them it shows none. I can connect fine via the phone's browser etc just not on tomtom plus.
