I use a RSA securid card to connect to my employers intranet and download Lotus emails; apparently this functionnality is taken symbian series 60 devices.
Is there anyone familiar with certification and securid card login ?
If you have a Nokia VPN gateway, then the nokia Mobile VPN client software and a suitable configuration policy (created by the Nokia Security Service Manager that you should get with a Nokia VPN gateway) will let you open a VPN tunnel to your company's Intranet using an RSA SecurID card for authentication.
If you can use the SecurID card for other kinds of authentication (e.g., as your email username and password, for web authentication, etc.), then it should be OK, too. (But security for the connection depends only on SSL/TLS in that case.)
