Well, maybe this is the wrong forum but i got a N91 whit a blank screen with the nokia word on it, do anyone knows how to get it back to life???, this happened after i tried to flash it using phoenix.
cheers 😃
Dx
cheers 😃
Dx
_Dx_ wrote:Well, maybe this is the wrong forum but i got a N91 whit a blank screen with the nokia word on it, do anyone knows how to get it back to life???, this happened after i tried to flash it using phoenix.cheers 😃
Dx
If you are lucky a Hard Reset will get it working again...
The N80 hard reset procedure is as follows...
1. Power off the phone
2. Press GREEN, * and 3
3. Power on the phone (still holding down all three keys above)
4. Wait 60 seconds (still holding down all three keys above)
I don't know if the N91 has the same hard-reset procedure but it's worth a try.
I had this problem with my N80 for a while. Thought it was a brick until I took out the memory card and SIM and powered it back on.
Next, power off and power on with SIM and you should be back to normal. and then you can finally try plugging in your memory card.
