Apps Not Going to Standby
2 replies · 1,414 views · Started 20 December 2006
I am having an issue that maybe someone will be able to help me with.
None of my applications are going on standby. I will be using an app then press my camera key for example.
When I check in taskman or holding down the menu key, the app seems to have closed.
It happens to a lot of apps such as agile messenger, photorite, internet browsing.
Any ideas?
Welcome to 3rd S60. This is written into the software, unlike previous S60 versions. It took a little time for me to get used to that. Get into a habit of using the menu key to exit the program, and once it enters the menu, then you can hit the end key. That will leave the apps running.
