Opening .cab files
2 replies · 2,403 views · Started 20 December 2006
Hi all, is it possible to open .cab files on my N80? seem to be having a lot of trouble installing something. Just refuses to open the file.
If it doesn't, is there a program i can install to open them, or should i re-save them in a different format before transferring to the sd card?
Cheers
James
A .cab file is an archive/package file format by Microsoft for Windows. There's no built-in support in any Nokia phone to handle .cab files. I don't know of any add-on apps for the phone for that, either. Extract what's in them on a PC.
james b wrote:Hi all, is it possible to open .cab files on my N80? seem to be having a lot of trouble installing something. Just refuses to open the file.
Cheers
James
I don't think the N80 supports CAB files, as this is a Windows format.
Are you trying to install TomTom Navigator 6? If so, you are trying to install the wrong version... you need the Symbian OS version.
