E61 Battery Indicator Problem
4 replies · 2,744 views · Started 21 December 2006
The battery indicator of my E61 is not updated correctly.
While using it, it keeps showing a full status (5 bars).
Only after turning the phone off and on again, it shows the right battery status (e.g. 2 bars).
Did somebody else have this problem too?
How can I solve this?
Will a firmware upgrade fix this?
Thanks in advance,
Randy
welcome.
which firmware are you running, i run v2 and have not seen this also which theme as i have noticed some themes have erroenous display issues.
Randyw, what version of the firmware are you using? This problem has been reported under version 1 of the firmware and has been reported (but not confirmed by me) as being fixed under version 3 of the firmware.
Mark
Randyw wrote:The battery indicator of my E61 is not updated correctly.
Thanks in advance,
Randy
I have the same problem with you and my firmware is version 2.0618.06.05
