With new software in the guise of a multi-alarm utility and classic Reversi, Epocware are hoping to occupy more of your phone's RAM...
Handy Reminder
Handy Reminder for Nokia 7650 is a great multi-alarm software tool. Handy Reminder utility allows you to create up to 7 different clock alarms at the same time.
Handy Reminder for Nokia 7650 supports the following types of alarms:
Once The alarm activates at a specified date and time. The alarm is then deleted.
Daily The alarm activates at a specified time every day.
Weekly The alarm activates at a specified time on the same day every week.
Workdays The alarm activates every working day at the specified time.
In the next version (upgrade is free): Setting different alarms sounds
Handy Reminder program interface is available in English, German, Italian, Portuguese, Norwegian, Russian, Czech, Hungarian, Finnish, Swedish, Dutch, and Spanish.
Handy Reversi
Handy Reversi for Nokia 7650 is a popular classic Reversi game. It will capture you and give you hours of pleasure.
Reversi game is played on an 8x8 square board. You have black disks and your opponent (your Nokia 7650) has white disks. The object of the game is simple: dominate the board with your color!
Players take turns one after another placing one disk on the board. A player's disk must be placed next to one of the partner's disks to create a capture.
Capture is when any of one player's disks that are surrounded at both ends (in any direction) by another player's disks. Captured disks then are converted to another player's color.
When it is no longer possible for either player to move, the game is over. Disks are counted and the player with the majority of his color disks on the board is the winner.
In Settings you can select one of four skills levels: from Easy to Expert.
