In the past I used to be able to access my gmail account (on o2) with my N80 to check my emails and send.
I recently updated the firmware.. and had to input all the settings again..
I input the settings below, and can check my email.. However I Cant send any?
Any ideas anyone?
SETTINGS:
Swirly Menu button -Messaging - Options (key) - Settings - E-mail -Mailboxes - Options (key) - New mailbox - Start (wizard) - POP3 - [email][email protected][/email] - (incoming) pop.gmail.com - (outgoing) smtp.gmail.com - (access) always ask (or whatever you want) - [email][email protected][/email] - Finish
Mailbox in use - [email][email protected][/email] -select
Mailboxes - [email][email protected][/email] - select - edit - Connection settings - Incoming email - User name: [email][email protected][/email] - Password: your password - Incoming mail serv: pop.gmail.com - Access point in use: Always ask - Mailbox name: [email][email protected][/email] - Mailbox type: POP3 - Security (ports): SSL/TLS - Port: (user defined) 995 - APOP secure login: Off -
back
Outgoing mail - My e-mail address: [email][email protected][/email] - User name: [email][email protected][/email] - Password: your password - Outgoing mail serv.: smtp.gmail.com - Access point in use: Always ask - Security (ports): StartTLS - Port: (user defined) 465 -
back
back
User Settings - My name: [email][email protected][/email] - Send message: Immediately - Send copy to self: no (or Yes) - Include Signature: No (or whatever) - New e-mail alerts: On (or whatever) -
back
Retrieval settings - E-mail to retrieve: Msg. & attachs. - Retrieval amount: 30 (or whatever you define)
back
Automatic retrieval - Header retrieval: Disabled (or whatever)
Getting a bit frustrated!
Thanks x
