Wi Fi
0 replies · 1,331 views · Started 22 December 2006
I have got an E60 and a N80. My router is Linksys WRT54G ver 5. with the N80, i am able to access shared files on my laptop. I installed psiloc's hotspot finder which seems to login correctly to the router. I can successfully ping the router.
but when i try to access the web, in both the phones i continue to get the "gateway no reply error". I must have tried each and every possible combinations.
The following are the settings up i am running right now. Can somebody guide me?
ROUTER CONFIGURATION
My router: linksys WRT54G
Router�s IP address: 192.168.1.1
AutomaticConfiguration-DHCP
DHCP Server: Enable
Operating Mode: Gateway
Security Settings
Security Mode: WEP (I also tried WPA Personal & WPA2 Personal)
Default Transmit Key: 1
WEP Encryption: 64bits 10 hex digits
Wireless MAC Filter: Disable. (Tried with enable - Generated Wireless MAC List. E60 turned out to be 00:15E:6A:E5:BB)
Firewall settings
Block Anonymous Internet Requests: On
Filter Multicast: On
Filter Internet NAT Redirection: Off
Filter IDENT(Port 113): On
MOBILE SETTINGS
Network status: Public
WLAN netw. mode: Infrastructure
WLAN Security Mode: WEP
WLAN Security Settings:
WEP Key in use: #1
Authentication type: Open
WEP Key Settings
WEP Encryption: 64 bits
WEP Key format: Hexadecimal
IPv4 settings
Phone IP Address: 192.168.1.101
Subnet Mask: 255.255.255.0
Default gateway: 192.168.1.1 (my router�s IP address)
DNS Address (obtained by �ipconfig /all�
Primary DNS Address: 203.115.71.66
Secondary DNS address: 203.115.81.38
Wireless LAN settings
PowerSaving: Disabled (also tried Enabled)
Someone please guide me.
