Can't do contacts transfer from 6630 to N73
2 replies · 8,258 views · Started 22 December 2006
I recently got a Nokia N73 and wanted to transfer my contacts from my Nokia 6630. I enabled Bluetooth on both devices and paired them with no problem.
However, when I try to open the file sent by the 6630, my N73 reports with "Installation of DataMover.sis is not supported". I'd be quite surprised if there was an incompatibilty since the 6630 is hardly the oldest phone around.
Anyone suggest any other way I might set about doing this?
Any help much appreciated.
mrbarlow wrote:I recently got a Nokia N73 and wanted to transfer my contacts from my Nokia 6630. I enabled Bluetooth on both devices and paired them with no problem.
You're doing it the wrong way around. You run the Data Transfer app [SIZE="2"](Menu > Tools > Transfer)[/SIZE] from the N73 and it installs a .sis file onto the 6630 and pulls the information over.
Thanks, but that doesn't work either. The 6630 just doesn't open the Bluetooth message sent by the N73 :frown:
