Making Your Own Custom poi Warnings TomTom Help Help !!
0 replies · 2,163 views · Started 22 December 2006
Hi all, ive been reading the link with part of the file ive copied below
For each of your OV2 files, create a warning sound in OGG format with exactly the same name. So if you have a BP.ov2 file, create a BP.ogg fileand place it in the same map folder. (We recommend 22050 Hz sampling rate but it should not matter)
Ie to the above can anybody give me more detailed instructions, also has anybody got theese working ok ( your own custom warnings on Nokia N80?.
Any Help please Please.....ie how do you record/convert/place etc.....http://tomtomsatnav.info/realvoice.html
Regards from brian p-s have a look at link above for me, i dont uderstand how to do !!!!!!! Thankyou
