problem tom tom sat nav 5 nokia 6680
2 replies · 3,171 views · Started 22 December 2006
hi all thanks for letting me on this mint site. trying to install tom tom 5 when installing it. its says cannot read files. it installed ok on my nokia 6600. can u help
It can be a bit of hassle installing it onto 6680. I also have TTN5 on my 6680, and it works fine.
How are you installing TT? eg from cd to your memory card via card reader?
Here's my experience of installing onto MMC:
Firstly, make sure there are no hidden files on the TT folder. Then install all folders from TT cd onto your MMC. Make sure that all ten or eleven TT folders are in the root directory of your MMC.
THen re-insert your MMC into phone. I found that ineeded another sis file, which I found on the internet. THis is a TT installation sis file.
If you have to try a re-install of TT, I belive you have to completely re-format yout MMC, as any traces of a previous install will throw a spanner into works.
Good Luck.
nottmbantam wrote:It can be a bit of hassle installing it onto 6680. I also have TTN5 on my 6680, and it works fine.
Good Luck.
nice 1 al give it a go many thanks graham
