N93 users: how bar code reader works? Is now available for N73 and N80. But how it works:con? I can�t reader any bar code:frown:
Bar code reader
nj7 wrote:N93 users: how bar code reader works? Is now available for N73 and N80. But how it works:con? I can�t reader any bar code:frown:
Works well! Aim for the bar code so it fills the screen and let the camera zoom and focus properly. This may take a few seconds and good lighting always helps. The bar code information is then extracted into a text field that you can save if you want.
Have tried it on non standard bar codes, with no success. Works fine with barcodes found on most grocery products and all 2D barcodes I've seen.
Hello, I have N73 where to get the Barcode reader please give me the download site thank you!
Is on phone Catalogs!
and what are we supposed to do with this info we scan?? kinda pointless so far??
Test it on Darla's site, there is a barcode, point it at your screen and it should work:darlamack.blogs.com
(scroll down , it's on the right)
