Hello everyone, glad I found this forum.
Did a bit of searching, but didn't come across a similar thread - any help is appreciated:
I recently got the e61 - yesterday I updated, things work swell - even wifi, which was iffy before- EXCEPT that now voice dialing simply doesn't work.
Voice COMMANDS work fine. I just can't dial by name. After speaking it just stops and returns to the standby screen.
The only thing I can think is that I have too many contacts (360+)
This happs both using the phone or the BT headset.
BEFORE the upgrade, voice dialing only worked for those people to whom I had given nicknames.
Any ideas?
Great, this is exactly the problem I need.
There doesn't seem to be any way to disable voice dialing, which is a bit iffy given that the tags are assigned automatically. So I occasionally end up calling people, especially ones with short names or nicknames, when I have a BT headset in my pocket.
Do post if you figure out the cause.
For me the voicedailing is still working after the ROM upgrade on my E61. I have about 700 contacts and it works great using or the bluetooth headset or the phone.
There must be something else wrong.
Wouter
I'm having the same issue on a N80 after updating via PC Suite. Any ideas anybody?
Greg
Hi.
On my E70 I had same symptoms after the upgrade.
I then changed phone language to something else, and then back to english.
This fixed the No Voice Dialing problem for me.
Hope this helps everyone with the same problem.
-- Niko
