Unable to delete folder in apps menu
3 replies · 5,521 views · Started 23 December 2006
Running into a bit of a problem...
I recently swapped out my 64mb card that came with my Nokia 6682 with a 512mb card. For some reason, when I put the new card in, an "Imaging" folder has now appeared in the menu (empty). I can rename it. I can move things in and out of it. But if I try to remove the empty folder (to tidy up my apps menu) it quits out of the menu screen back to the standby screen. If I go back to the menu screen, it's still there.
I've tried renaming it and then deleting. I've renamed, power-cycled the phone, and then tried deleting. Nothing seems to work. Help?
