Docking Station for E61
5 replies · 4,691 views · Started 23 December 2006
twillingham wrote:Found a nice docking station on ebay.
I bought one of these as well. Does your's have a blue light on the bottom right hand side that flashes from time to time? Any idea what it means when it's flashing?
Yes I have the cradle with the blue light but mine does not flicker. I noticed that when I tried to use the usb cable that came with the cradle it caused my phone to constantly reboot. Then I used the Nokia usb cable and it worked just fine. However, sometimes when I sit the phone in the cradle even with the Nokia USB cable the phone seems to have problems and constantly reboots but if I connect USB straight to the phone that does not happen. I wonder if the third party cradle is not quite up to par Is anyone experiencing this or similar problems 🙄
Hi Twillingham, you have changed your title to E62 from E61, is this the case?
As I said I my post I got one from ebay which is black and quite solid with a blue led in the bottom right and works fine. I did post the url to the supplier for others but had the post deleted!!
Yes, I made an error originally, I have a E62. I have the same station you have with the blue light. I figured out my problem with syncing with the station. I have a four port USB hub which is a 1.1 USB hub which is outdated. This cable from Nokia is probably 2.0 and cause a problem when attached to the station. now I connect directly to my laptop and it works flawlessly everytime.
