6680 problem
9 replies · 2,426 views · Started 23 December 2006
I have Nokia 6680 unlocked to any network. I put an O2 Pay As You Go sim inside, and tried to dial a contact from the contacts list. It would let me the first time, but not again after that. It you input the number manually, it works fine. When another network sim is put in, it works fine. I contacted O2 and they sent me a brand new O2 Pay As You Go sim card. I trieed it again, and still nothing!
Can anyone help????
nj7 wrote:Weird... Do a phone reset, and maybe is enough...
have done that and its just the same cheers thank. can u think off anything else
The next step is a phone format, but is most destructive... the lost is total:icon4:
nj7 wrote:The next step is a phone format, but is most destructive... the lost is total:icon4:
nice 1 how do i go about doing that.thanks for getting back to me cheers graham
First, do a phone backup, to the card and to PC with PCSuite. After that, two ways, soft format: *#7370# or even more higher format, an hard format: * + 3 + green key and power on. All personal things inside are lost...
nj7 wrote:First, do a phone backup, to the card and to PC with PCSuite. After that, two ways, soft format: *#7370# or even more higher format, an hard format: * + 3 + green key and power on. All personal things inside are lost...
It's worth noting that when doing the hard format, you should hold the *, 3 & green (dial) key down when powering up and keep holding them down until you see the word "Formatting" on the screen.
cheers am going to have a go tomoz ive ad a couple off drinks.al get back to you tomoz and let you no the outcome. many thanks graham
graham2900 wrote:cheers am going to have a go tomoz ive ad a couple off drinks.al get back to you tomoz and let you no the outcome. many thanks graham
hi that took some doing but its just the same.i dont no what ta do is it a basket case. cheers for what youve done so far. and have a happy christmas. graham
graham2900 wrote:hi that took some doing but its just the same.i dont no what ta do is it a basket case. cheers for what youve done so far. and have a happy christmas. graham
sent the phone back the guy i got it of say he will have a look at it and let me no the outcome. so i am useing my 6600 happy days. let you no the outcome many thanks graham
