Group 0 - what's this?
16 replies · 3,432 views · Started 23 December 2006
Folks,
On my E61, there's a zero at the side of the battery level indicator, and below it, where the operator info blinks and the bluetooth/wlan signs shows, it also sometimes appear the words "Group 0",.. What's that??
Yours,
oculos
I�m not sure about that... Seems network status area... but not sure. And network area usually is a number code. I also check, and the manual does not have anything related:con?
exactly... i never seen this... and i try to disable status messages, but it doesn't go away...
Do you have an access point group with this name ?
Do you have an active wifi connection ?
If you switch back to the default Nokia/Theme skin does it go away ?
ozy:
no access point with that name, though I do have one access point configured and one group with 2 access points, but it's not named "Group 0"...
and yes, it remains when I switch back to nokia's original theme...
oculos wrote:Folks,
Yours,
oculos
Hello oculos! What you're talking about is the 'Closed User Group'. To remove it from the screen, do this:
Settings -> Security Settings -> Closed user group. Change it to 'Off'.
-Absi
absi wrote:Hello oculos! What you're talking about is the 'Closed User Group'. To remove it from the screen, do this:
-Absi
Thanks a lot Absi!!!!!!!! 😃 😃 😃
But, do you know what's that little circle at the side of the battery level indicator?
yours,
oculos
oculos wrote:Thanks a lot Absi!!!!!!!! 😃 😃 😃
yours,
oculos
Hello oculos. I don't have an idea of a little circle at the side of the battery level indicator? Can u post a screenshot of it to make me get a more description of what you're refering to..
-Absi
oculos wrote:Hello Absi!
There's a screenshot above in this thread...
cheers,
oculos
Then the circle you're referring to is a '0' (zero)? Then it would go away by the steps i told above. Hope this is what you meant.
-Absi
absi wrote:Then the circle you're referring to is a '0' (zero)? Then it would go away by the steps i told above. Hope this is what you meant.
-Absi
Nope, it didn't'.... the group 0 message did go away, but not that 0 - i'm not sure it's a zero though... I have no idea about what it is really, it's just there...
oculos wrote:Nope, it didn't'.... the group 0 message did go away, but not that 0 - i'm not sure it's a zero though... I have no idea about what it is really, it's just there...
In that case, then I don't know! Sorry! N btw, you told a screenshot is posted above, but that circle u'r referring to isn't there..
lol!!!
True...
But...wtf???? Why do we need an icon there? Don't we know we have batteries on cellphones??? duh!!! 😃 And at the right side there's a battery level sign, so...
thanks Mark!!!! 😃
