Hi, i just upgraded my N91 to
v 2.10.013
27-09-06
RM-43
N91 (39.01)
using nokia software updater, im on vodafone, after it restarted i plugged again the usb cable and nothing happened, ive tried formating it using 3 green * and *#7370# and soft and hard format on the phone but nothing happened, i just plug the usb cable and nothing happens, i hope someone can help me. chhers
Dx
Nothing happens on the phone or on the computer, try to reinstall the nokia pc suite.
SpeTz wrote:Nothing happens on the phone or on the computer, try to reinstall the nokia pc suite.
didnt work 😞 any other ideas?
what happens when in pc suite u click on the bottom where it says get connected
it opens a menu, and asks wut kind of connection i would like
Continue by selecting data cable and connect the cable when it asks you. It worked when i connected my old phone by connecting the cable right after it is said in pc suite
_Dx_ wrote:Hi, i just upgraded my N91 tov 2.10.013
27-09-06
RM-43
N91 (39.01)
Dx
Sometimes after a FW upgrade you need to format the phone memory.
*#7370#
dez_borders wrote:Sometimes after a FW upgrade you need to format the phone memory.*#7370#
i tried both options and it doesnt work =( any other ideas??:con?
