N91 USB port stopped working after NSU finished the firmware upgrade
2 replies · 5,066 views · Started 24 December 2006
Hi, i just upgraded my N91 to
v 2.10.013
27-09-06
RM-43
N91 (39.01)
using nokia software updater, im on vodafone, after it restarted i plugged again the usb cable and nothing happened, ive tried formating it using 3 green * and *#7370# and soft and hard format on the phone but nothing happened, i just plug the usb cable and nothing happens, i hope someone can help me. chhers
Dx
Hi
My bet is its your PC. SOme PCs have issues with a device that is "new" but really isny new. I had a prblem with a fancy (too fancy) card reader that I updated the firmware on. Then my PC could see it anymore...its like it did not recognize it as "new hardware" or remembered the old one. Try this
1) Try renaming your HDD on the N91
2) Try uninstalling and re-installing the USB driver on the PC (this is what fixed it for me in the situation above). Its is really rather easy
music
