Video capture lenth
16 replies · 2,843 views · Started 16 December 2002
Im using tmobile vid capture thing [with English trasnlation thing - THANK YOU who ever made that!!!] Is there one that records clips of longer than 15 seconds? Ive noticed it auto stops after 15 seconds...
edit: Im on FW ver 4.36
[quote="JyriK"]there is that 100kB limit that comes with MMS, thats why.[/quote]
So nothing i can do to change it - no settings in the t-mobile thing i can change?
If it has a configuration file that contains the setting, I guess it could be changed. Just a thought though.
[quote="kobe24"]If it has a configuration file that contains the setting, I guess it could be changed. Just a thought though.[/quote]
Any more info on this before I go on a quest of changing?
Well, most applications make use of a configuration settings file, or in Windows, its the Registry.
These config files are there in order to avoid some hard coding. This is to make the application a little more flexible. These files are usually in the form of .ini file. I'm still not familiar with the Symbian OS if it does use the same type of file. But, I bet it makes use of such a file.
If you happen to get it, please send me a PM. 😃
[quote="PURPLEMUSTANG"]wasn't there a program called pocket video that fixes the problem?[/quote]
I think he emphasized using T-mobile video... and not another application. 😉 .
[quote="kobe24"][quote="PURPLEMUSTANG"]wasn't there a program called pocket video that fixes the problem?[/quote]
I think he emphasized using T-mobile video... and not another application. 😉 .[/quote]
Yep! As the only other one i know is PV and thats Rubbish! With a Capital R! O will have to get this tmobile one to make longer recordings!
No it does not,its a diferent application.
I cant tell if it is rubish or not,i haven't tried it.
Wind's VideoMMS is based on it.
One more thing.
Changing the 100 KB file limit would be considered illegal.
[quote="GhostDog"]
One more thing.
Changing the 100 KB file limit would be considered illegal.[/quote]
Why the illegal thingy 😞 ?!
and whats Wind's VideoMMS?
At times, the Configuration files are for advanced users. User's at their own risk. So I would say that it is legal. 😃
What's with PURPLEMUSTANG anyway, I think he's a bit rude. Seen his posts lately?
[quote="kobe24"]
What's with PURPLEMUSTANG anyway, I think he's a bit rude. Seen his posts lately?[/quote]
Hmmm ...
VideoMMS is an Audio and Video recording app provided by Wind (Italian operator) for its users.
The 100KB limit is not storet in configurations setings.
And no,i haven't read any rude post by PURPLEMUSTANG
[quote="GhostDog"]VideoMMS is an Audio and Video recording app provided by Wind (Italian operator) for its users.
[/quote]
Is it freely availble? Please can u post it or email it please?
do you know where the 100kb limit is 'set'?
Thanks ever so much! 😊
No,VideoMMS is not freely available,you have to pay for it (Its a small amount of money) but the problem is not the payment,VideoMMS is available for italian operator users only.
Are you italian? 😃
