So cut the cwap - Heres the question that does'th plague ones mind
if the manager reports this:
11kB Calendar
104kB Contacts
144B Documents
27kB Messages
256kB Images
28kB Sound Files
590kB Applications
3636kB Mem. in use
457kB Free Memory
Well what I dont understand is - that all equals to aprox 2.8MB - Then why the hell does it say 3636kB Mem in use if its only report in total off 2.8 used?! Im confussed!!! I wanna my space back!
For some stupid reason, the App. Manager only shows *.jar applications you've installed and not your *.sis
The first screen shows your *.sis so don't forget to add those as well.
And the rest of your missing space is probably being used by registry and useless data from previous installs.
[quote="MR-6T9R"]For some stupid reason, the App. Manager only shows *.jar applications you've installed and not your *.sis
And the rest of your missing space is probably being used by registry and useless data.[/quote]
USELESS DATA!!! [I recently wrote a post expressing i was on a quest against the affor mentioned dirt] Where abouts do you know anyuseless data coagulates?
[quote="Zipper"][quote="MR-6T9R"]For some stupid reason, the App. Manager only shows *.jar applications you've installed and not your *.sis
USELESS DATA!!! [I recently wrote a post expressing i was on a quest against the affor mentioned dirt] Where abouts do you know anyuseless data coagulates?[/quote]
Most of the useless data I've found were to be in C: root folder. But be careful not to delete a component of an application is installed. You can delete components of the applications that you've removed.
I had the trial version of Handy Safe. after finding it wasn't of any use to me, I deleted it. Using a file manager, I found that a Handy Safe component was still in my C:root folder taking up 16kb (the little bastard)
yes all the handy what-noy programs do it.
and bu the way all the handy programs suck.
[quote="PURPLEMUSTANG"]and bu the way all the handy programs suck.[/quote]
Not at all. Maybe for you, but I don't see the reason why you should generalize it.
Handy Safe is a good App.
[quote="kobe24"][quote="PURPLEMUSTANG"]and bu the way all the handy programs suck.[/quote]
Handy Safe is a good App.[/quote]
I totally agree with this. Handy safe is good app, who should always remember those stupid PINs? Now I can have them in my cell phone 😊
