PC Suite Nokia App Installer
6 replies · 3,495 views · Started 25 December 2006
When in Nokia App Installer The box on the right gives me the following message. "The contents of the current selected phone model cannot be shown by this application" Why cant my phone info be displayed. Has anybody experienced this with the E62
Is the phone connected via pc suite, sometimes my n80 has the same thing and isnt connected. If the phone is connected before the installation it should just give you a pop up that says to install right away without going to the app installer.
PC suite auto starts at startup and auto connects via Bluetooth and syncs every 30 minutes. When I use the install app section it gives me the message about my phone. How can I get it to reconize my phone in this feature. My phone is connected to pc suite. The app installer just isnt able to see contents of my phone
Remove all from PC. Clean registry and delete all entries PCSuite related. Reboot the PC and install again the PCSuite last version from Nokia Site. Should work.
PC Suite's Application Installer cannot list/display any installed apps on any S60 based phone. In other words, you can use it to install new apps, but not see those that have been installed alread.
