Does somebody know how to upgrade firmware on nokia 7610?
My firmware is:
V 5.0509.0
28-02-05
RH-51
Upgrade Nokia 7610 Firmware
Take it to your nearest Nokia service/repair center and ask them to do it. You can try to locate one through these pages: http://www.nokia.com/repair
i found this
1. Disconnect the charger and remove the battery.
2. Wait for at leats ten seconds and insert the battery to start the device.
3. When you see the NOKIA Welcome screen, immediately press and hold down the [= (Left Key) +Menu [.-
The Key [.- should be press at last.
4. Confirm that you want to format. Formatting start.
Pleaz i dindn't localized those keys,
sorry to be so stupid
i'm using nokia 7710 and my touch screen doesnt function since 2 day, so help me to format all.
