N73 ME or IE upgrade question
5 replies · 3,216 views · Started 26 December 2006
I've just succesfully upgraded my
2.0628.0.0.1
RM-133 (49.02)
Nokia N73 (0539335 product code)
to Version 3.0638.0.0.30 Music Edition with the 0537289 (Euro1) Product code.
I'd rather had the Internet Edition, since I like the old function of the media button, but i didn't do that because i read on the forum that it only supports English and Asian dictionaries.
The flash went perfectly, however, This productcode apparently doesn't support Dutch (T9) either (maybe I should have chosen Euro2?).
Is there anything I can do to get my T9 Dutch dictionary back?
I read it is impossible to downgrade firmwares. If I change the product code again to a Euro2 code, will it flash?
If there isn't a solution on getting the Dutch dictionary back, so be it. In that case i'd rather have the N73 Internet Edition (thus it also supports English and I rather have the old media key). Is it possible to change the product code to an Internet Edition one and let it flash again?
Thanks!
clovis_ll wrote:whats the difference of ie and me?
Nothing, except that the IE version comes with a few extra Internet apps pre-loaded, like MSN Messenger. All of these, AFAIK, can be downloaded seperately anyway. It uses the same core firmware, so no advantages system or performance wise.
Well, to be honest, I don't like the function of the media key in the Music Edition.
But anyone got an answer to the first questions?
Cusem wrote:Well, to be honest, I don't like the function of the media key in the Music Edition.
TBH, I found the Media key function pretty cumbersome so it's not too missed here.
As for getting back other languages, well, all I can think of is to change the product code to one that will contain the relevant language pack, then run NSU again. This will probably (and I say probably because I haven't tested this) come back with a response of "Latest Firmware installed, would you like to re-install". In which case you should say yes and then see what happens.
This is merely a suggestion but it's what I would probably try in your situation.
