Can somebody please help me..? I have had my new Nokia N80 phone now for around 2 months now and there is not one ring tone that that I can handle, it is embarrassing every time it rings. I was hoping that somebody may be able to help me with some professional business type ring tones. I am almost at the point where I want to replace it just because of the childish ring tones. Any help would be much appreciated�
Business type ring tones for N80...Please
erm, isn't ring ring plain enough for you?
Awful wrote:Can somebody please help me..? I have had my new Nokia N80 phone now for around 2 months now and there is not one ring tone that that I can handle, it is embarrassing every time it rings. I was hoping that somebody may be able to help me with some professional business type ring tones. I am almost at the point where I want to replace it just because of the childish ring tones. Any help would be much appreciated�
What's wrong with the built-in Nostalgia ringtone? It's a basic ring-ring. 😉
Ring ring is the best business ring tone for the phone but since the first firmware update is now missing. I had to get it from my 6680 using Fexplorer as it's on the phones rom. If you google "Nokia ring ring" you might find it.
hope this helps
why dont you try to make your own?
Thanks for your feedback. But I have searched for ages on the internet and had no luck, there has to be something out there as I'm sure I'm not the only one that�s frustrated with what�s comes with the phone. Can somebody recommend a program that I can program one with, or better still I was hoping that someone has some normal type ring tones in a compatible format to post on this forum...Thanks...
If you have Yahoo! Messenger installed there's a file called ringring_03 in the C:\Program Files\Yahoo!\Messenger\Media\RingTones folder which may be what you're looking for.
No Worries, thanks I'll check it out...
