how to delete applications?
2 replies · 2,421 views · Started 29 December 2006
how do i delete applications which i have installed? i have connected to computer via usb and non of the applications i have installed are showing up; therefore i cannot delete them. is there someway to delete them through my n70? where do i go? thanks in advance
In addition, there are times some applications can't be deleted the normal way then install file explorer and remove the applications manually.
