Loose slider
4 replies · 1,985 views · Started 29 December 2006
Has any ones slider become loose or not as tight as it used to be? Mine seems to be getting looser and looser, It now twists slightly side to side when closed if you know what i mean.....is there any fix for this? does anyone have a pic of the internals of an n80 slide phone?
some good answers there, keeping it open stops the movement for sure, but im still non the wiser:hmmmm: Ive not opened the phone YET.. but i presume these slider parts are plastic? anyone else
There's a metal bracket behind the 'middle' part of the phone. If you open it up this can be carefully bent outwards slightly, which will tighten the slider.
