I just got my phone a week ago. And I was wondering if there an airplane mode on the n80?
Airplane Mode
Press the power, then select offline.
This will stop the phone sending or receiving a signal.
But if you are spotted with your phone the cabin crew more than likely will ask you to power it off.
Just be discreet with it and try not to freak out other passengers..
Dont even bother try'n to explain to people it has an offline function, they just dont get it..
thanks. that helps alot.
icemanjimbo04 wrote:Press the power, then select offline.This will stop the phone sending or receiving a signal.
Easyjet know about the air plane mode on planes and allow it, they mention it in their safety check...lets hope more airlines follow 😊
