Whem I updated my firmware N80 I found the following entries in the AppsManager:
search-localplugin-UK
search-localplugin-DK
search-localplugin-FR
search-localplugin-ES
search-localplugin-NO
search-localplugin-SE
search-localplugin-FI
search-localplugin-HK
search-localplugin-IT
Are these programs necessary altogether? Or can I delete those which do not belong to my country? What are these programs needed for?
albert1234 wrote:Whem I updated my firmware N80 I found the following entries in the AppsManager:search-localplugin-UK
I had them as well, i think they belong to the Search application, i uninstalled it and all these plugins, had no problem. If you don't use Search app should be ok.
how did you uninstall these... did you clear on the app. man. list or remove them via some other method...
when Ive tried to remove them via app man but although they seem to delete, they dont actually go!? 😡
