I was wondering if anybody knew if the tv/video out cable for the n93 would work with the n80? If it does would I need a special program to run it? Any help would be greatly apprieciated. Thanks.
TV Cable
Doesnt the n93 tv out cable go into a special slot? meaning it wouldnt work on the n80
Well the tv out cable go in the PopPort with the n93. So would there be a big difference in the popports between the two phones? Because I've use the radio headset with my n80 and my old nokia 6800 with no problem with the ports.
Is not only a question of pop-port. It need dedicated software for that. So, only N93 can do that... and N95, soon.
You can connect your phone to the computer and stream videos and pictures thru the xbox 360
