I just got an N73 on Tmobile and im really chuffed! Ive heard tomtom sat nav can be installed?? Can someone please advise on what steps are needed to get this PLEASE??!!! would really appreciate it!
SURAJ_ADATIA wrote:I just got an N73 on Tmobile and im really chuffed! Ive heard tomtom sat nav can be installed?? Can someone please advise on what steps are needed to get this PLEASE??!!! would really appreciate it!Thanks
Well, first you buy the software either on DVD or MiniSD from TomTom or an authorised retail outlet. If you buy the version on MiniSD, you just pop the card in and away you go. If it's on DVD, you essentially copy the files for your particular phone over to your existing memory card you're sorted.
I should, however, point out that at this moment in time, TomTom Navigator 6 is not offically supported on the N73, but it does work as I have it running on my N73 here. TomTom only officially support the E50, E61 & N80 at this time.
You will also need a Bluetooth GPS Receiver. You can buy a version of TomTom with one or you can buy one seperately from places like eBay for about �35 GBP.
Good luck.
