zoom on the N73 piano edition?
3 replies · 2,671 views · Started 01 January 2007
does it have stepless zoom or is it like te n80??? and how loose is the slide part on the phone?? pease reply THXX
armada741 wrote:does it have stepless zoom or is it like te n80??? and how loose is the slide part on the phone?? pease reply THXX
First of all....
Piano Edition ?!?!?!?!?!?!
Anyway, no, it isn't a true stepless zoom, but the camera is much better than the N80 as the N73 has a Carl Zeiss Tessar lens, proper auto focus and a mechanical shutter and a whole host of settings and functions.
When you refer to the slide, Im assuming you are referring to the lens cover ? If so, it feels very well sprung and very taut.
Hope that helps.
The lens cover is an incredibly simple mechanism; I've had mine for 3 months now, and it seems as solid as ever ... in that it doesn't feel that solid, but it doesn't feel any more loose now than when i first got it.
