E61 unable to send message
2 replies · 2,534 views · Started 01 January 2007
sending simple txt message fails with my brand new E61 after using PC Suite to send message. Then sending SMS from E61 also fails.
I have formated the memeory card. updated PC Suite and updated E61 via Nokia site. Everything works fine for a couple of days.
Then using PC suite to send 3 batches of SMS works fine before I got same error message again at the last batch: Unable to send message!
Now I am not able to send SMS at all. :con?
Thanks in advance for any help
which operator?, which firmware? are your sending to single recipients or multiple? are the destined to the same country or abroad? were they sent over the new year which is a know troublesometime for the mobile networks!!
Thanks Smallboy for your reply.
Operator:
Mobinil, EGYPT
Firmware:
3.0633.09.04
21-11-06
RM-89
Nokia E61
Recipients:
it happens for single and multiple recipents
Detination:
same country
The problem started during the new year but still exists after this peak period.
I guess operator/Network is not an issue as I managed to send SMS using same SIM card on my other Nokia 6260 without any problem. :con?
Regards
