Flash
6 replies · 2,866 views · Started 01 January 2007
When i try to open a flash document it says it is corrupted, tried many different files with no result. Please help.
i tried to play a .swf in both nokia flash and adobe flash both say file corrupted but works fine in pc
Yes, but is it a Flash Lite v1.1 .swf file or not? The phone will *NOT* play Flash Lite v2 files, nor "full" Flash files intended for PCs.
how do i know what type of flash file it is?
and can i change from a computer file to a lite file?
If you phone supports it (most recent Nokia models), download and install Flash Lite 2.1: adobe.com/devnet/devices/
Basically, you're trying to play a Flash document which was made for PC Flash viewers. Those do not work on Flash Player on the Nokia handsets =(
