how to you add items in the GoTo Menu?
11 replies · 3,005 views · Started 03 January 2007
so far as I know, there isnt an option to add to the 'goto' menu... which does make it pretty pointless... easiest way round it is either active standby editing or changing your softkeys.
raynos13 wrote:menu>my own> go to
Nokia N80 IE V4.0632.0.38
N80 still have that? Because N73 don�t!
I would use it all the time if I could actually add to it....otherwise like a few posts above have said....what is the point of it:stupid: Could this be a nokia fook up!
On the N80 it is not possible to add items to it, it just a leftover from the old devices
Only the networks can add shortcuts to GoTo in S60V3, and the function has now been removed from most new S60V3 devices like the N73 and 5500
using y-browser i have found out where these items are located within the phones operating system, i just can figure out how to add to them, they appear to be shortcut items, listed as...
CalendarApp.ink
MessagesApp.ink
NotepadApp.ink
anymore ideas???
