Polyphonic ringtone for nokia 92xx
12 replies · 4,087 views · Started 17 December 2002
is there any way you can play a midi tones in 92xx and set it as a ringtone...???
and what is the difference between wav and au format...???
does au size is smaller than wav...???
😛ainting:
I think wav is the smallest music format you can get on the 9210 (the compressed wav files that is)
Don't have more information ... 😊
MIDI no, but you can open a MIDI file in a ringtone editor and chose the instrument you want and convert that to a .rng tone.
yaa noticed that, it plays it like -Logomanger- on the PC.. 😃
but you can RECORD your polyphonic from 7650, 3510, 7210 & 6610 using the Recorder in your 9210 😊
and there is some Polyphonic tones posted in 92XX Multimedia forum.
I'm using a wav-file as a ringtone at the moment. I'm not sure if it counts as really polyphonic, but it's not like the usual beepy sounds. Of course, without stereo speakers everything you play will sound a bit flat.
wekk the wav files aretn politonic an so thers a very big deference between the original and a recording play during tha the 9210 has poor soudn quality for its years it sound good but for the todays standards no😞 listen to a s100 and you will ubndrstadn what i mean!
Yeah, but I can still record my wife saing Schatzie, was machst du? and can listen to her each time my phone rings...hohohoohoohoo
I meant that my 9210 has a litle bit of everithing (stop pronouncing GPRS or other useless staff..) and is by far the most advanced phone on the market...
[quote="TheSpecialBoy"]Yeah, but I can still record my wife saing Schatzie, was machst du? and can listen to her each time my phone rings...hohohoohoohoo
I meant that my 9210 has a litle bit of everithing (stop pronouncing GPRS or other useless staff..) and is by far the most advanced phone on the market...[/quote]
the same thing i've recording my wife till snoring ...nice sound hahahahaha
