can anyone suggest a compatible mini sd card i bought a sandisc mini sd off ebay only to find out that sandisc is not compatible with the n80 so i am looking for any that are compatible with the n80
thanks
mini sd cards
sandisk is completely compatible with N80, so its more likely that you got a fake sandisk off the bay 😞
Check out mobymemory. They are pretty well priced and I got a 2gb generic off them that works fine.
I agree with Kontaband. I had the same problem when I purchased mine of ebay, I eventually got mine of mobymemory and it works fine.
See the attached link of previous discussions.
http://www.allaboutsymbian.com/forum//forum/thread/49906/&highlight=mini
Check your N80 is running V4 firmware or later. V3 and earlier firmware were notoriously fussy with miniSD card compatibility.
I too run a 2GB Moby memory card without any issues, good price too.
S.
kontraband wrote:sandisk is completely compatible with N80, so its more likely that you got a fake sandisk off the bay 😞Check out mobymemory. They are pretty well priced and I got a 2gb generic off them that works fine.
Agree! Sandisk is 100% compatible.
thank you all for your reply i am running v4 but i must have bought a dogy card although it looks very convincing packaging , and warranty but never mind we always learn
well if it has got a warranty... you could go with that and try and get it replaced.
