what is the best firmware to use on N73?
5 replies · 3,496 views · Started 04 January 2007
Hi
what is the best firmware code to use on N73? ive upgraded to the vanilla euro1 0527009 but ive heard that the ME version is better.
whats the difference & what is the code i should use on NSU for the ME version?
Do i need to format the phone after as well ?
blobq wrote:Hi
Best firmware will be either Music Edition or Internet Edition. They both use the latest firmware core, but IE has a few extra little add ons like MSN Messenger app, but these can be acquired seperately anyway.
As for the code, that depends on your locality.
You don't need to format the phone, but you could if you felt you wanted to.
Hi Thanks for the info, im in UK, so do you know what code i use for the ME & IE edition ?
blobq wrote:Hi Thanks for the info, im in UK, so do you know what code i use for the ME & IE edition ?
I used 0537289 for the music edition, works a treat. Much better than my previous firmware..
lovesign wrote: IE has a few extra little add ons like MSN Messenger app, but these can be acquired seperately anyway.
Ahem.. IE also lets you use the multimedia key for something other than the music player 😃 .. The music edition launches the player. IE lets you use it (like the f/w before music edition)
