hi there! can anyone out there tell me
1. how can i key in the symbol above into my Write Mail.
2. which site can i get the Mocha PPP Client and Extendede Internet for Communicator on LAN
Thanks. :roll:
Thanks. :roll:
I would go this way:
For the @ symbol you can use the Shift + KEY that has @ with white on it. I have 2 locations
-English Menu -4-th key left to right last row(Is the row with spacebar 😉)
- Italian Menu 2-nd from right to left, 2-nd row from doun to up(below K key)
The e-internet and mocha (can someone tell me what is this mocha) can be found on psiloc site or here http://www.allaboutsymbian.com/software/directory/viewcat.php?c=Internet&d=Nokia%2092x0
Good luck
there are two selections,
for normal Home Build PCs runing on Intel chpis and with windows family
which one should i choose
Mocha EPOC-6 Telnet Mocha Soft Connect to an UNIX host with the TCP/IP/TELNET protocol and emulate a VT220 terminal.
Mocha EPOC-6 TN5250 Mocha Soft Connect to an AS/400 host and emulate an IBM-3179-2 terminal.
