Hi guys. Just want to put my 2 p
I have seen a lot of forums where people have tons of problems with n70, tt5 or tt5.2 software and receivers.
Honestly, I don't want to buy gps for my n70 until will know that I'll have no problems with that.
So, this is a main question.
Which soft/hardware works with n70 without any problems and Is it possible to find it????
The best source of this equipment for me is EBAY.
Honestly, I want to spend less money, as possible( I mean cracked software on mmc card and cheap bt or other receiver).
I'll be very appreciate for any information(facts, ideas, links).
Together we can sort out this problem😊
Take care of forum rules...🙄
About antenna, almost any one, if is a SiRF Star III, 20channel - more modern.
I prefer Nokia Ld-3W, because it uses the same battery and chargers, like the phone, but is not the most cheap on market.
Software, for me the best is TT5, and second best Route66. But have other alternatives on market.
nj7 wrote:Take care of forum rules...🙄
Hi nj7. Sorry if i'm did something wrong on forum.
Do you have nokia n70 with satnav?
no problems with it?
What about tomtom mobile v5.2?
Is it the best?
What I need to use I want to put tomtom program to the mmc? Cable with pc suite or card reader???
THanks for all information😊
dennnis wrote:Hi nj7. Sorry if i'm did something wrong on forum.
Is it the best?
N70 - not any more!
Any problem at all;
TT5.2 - works well without problems on N70, 6630, 3230 at least;
For me, yes, because of interface;
TT5 came with all you need, even with a receiver.
Or go to Route66, and buy a separate receiver.
nj7 wrote:N70 - not any more!
Any problem at all;
You don't using n 70 any more?😊
Did the tomtom solved problem with blue tooth conection with nokia n70 already???
I want download tt5.2 and buy receiver separately.
What about bt321 receiver with 32 channels? Guys from ebay saing that is the best from all on the market. Is it truth?
Dennis
dennnis wrote:You don't using n 70 any more?😊
Dennis
I don�t have the N70 any more. And, I saw TT5 work on an N70 from a friend, not mine. No Bluetooth problem at all.
TT5 is sell with the GPS antenna, not separately. So if the choice is TT5, theres no need for another antenna.
nj7 wrote:I don´t have the N70 any more. And, I saw TT5 work on an N70 from a friend, not mine. No Bluetooth problem at all.
Hi. I think is depends where to buy tt5.
I saw a few offers on ebay with tt5 or tt5.2 on mmc. just for 15 pounds without any receiver of cos
Those versions, are not legal ones, thats it!
and If I want a legal one. which is is the best tt5 or tt5.2???
What the difference between them, is it big?😊
TT5.2, is an upgrade of TT5. Search on TT site wich are the differentes.
