How can I edit startup of my n70? (add an applicatoin to startup!)
2 replies · 3,996 views · Started 06 January 2007
Hi...
I want to edit the startup options on my n70 to add an application to start up when i turn on the phone.......
Iv found a small application that removes the beep of any call recorder....it works great but the only problem is that i have to launch it every time i turn on my phone as it does not have an option to start automatically....so i was wondering if tehre is a file i can edit to manually define or add this application to startup...or if there is any program that can do that....
Thank you in advance...
RAwan ABu Salman
hi man, can you please send me that call recording software..i need it.
thanks in advance.
wael EGY
rawanabusalman wrote:Hi...
RAwan ABu Salman
