predictive text
3 replies · 1,558 views · Started 06 January 2007
hey guys , just wondering if its possible to add a language to the n80 , i would like to add polish predictive tex to my phone without deleting the english 🙄
I guess your almost trying to merge the 2 predictive texts of English and Polish in that way... and although Im sure for you thats useful, clearly not a thing nokia does.
Maybe theres a app that you can merge to 2 dictionary files into one... would need to research it a bit
[QUOTE=kontraband]I guess your almost trying to merge the 2 predictive texts of English and Polish in that way... and although Im sure for you thats useful, clearly not a thing nokia does.
yeah but if you go to predictive text i have english , spanish , french and some others but not polish , surley its just a case of adding the right files in the right place
yeah, Id think thats exactly what it is... but youd have to create or find a Polish language pack....
maybe you could use NSS to change the code to Polish N80 and upgrade.. and that would give you Polish AND English. What you think?
Although that wouldnt work if your already on latest version.
