hi i have a bluetooth enabled car stereo, until recently i had a samsung i300 that i could connect to the car and set it to auto answer through the car speaker after 3 rings. brilliant.
i now have the n80 that also works via the car stereo but i need to press the phone button to answer!
does the n80 have an auto answer feature that i can set up?
cheers wayne
Use: Menu - Tools - Settings - Enhancement - Bluetooth handsfree to access the settings for auto answer.
FYI if you're using the N80 with a Parrot Rhythm n Blue stereo you'll need to use Nokia's "Download Contacts" application to sync the phonebook with the stereo..
cheers taz thats set now just to try it
wayne
Don't forget - N80 bluetooth is unfortunately not stereo ... as I seriously would love to do the same (get a bluetooth stereo) not only because they seem cheap, but because I a couple of gigs of music on mine and the missus's phones!
If there is anyway of fixing that (without a plugin) I would love to hear it!
G
