Is there a working mp4 player for the N91 ?
I've hunted around various blogs, but cannot find any solution that works.
I basically just want to play downloaded podcasts (which are in mp4).
The sound is OK, but there is no video.
N91 mp4 player
The following gives a working solution on expansys.com/
ft.aspx?i=121479&thread=104
"first download mediacoder, (search google for it) activate nokia plug in, this will convert any videos ''mpg''wmv'' to nokia format mp4, send them via usb cable, easy, this is all free, took me ages to figure this out but it works, vids now play in stereo on fone, there are other versions of mp4 that do not work ''unknown file format'' but mediacoder works for me"
This does work by converting the mp4 file - it is about 1/3 the size
