N70 Gallery Problem, Screen, (using Music Edition)
4 replies · 5,102 views · Started 09 January 2007
I bought an N70 brand new with T-Mobile software after my last one died. I immediately flashed by changing product code and flashing to Music Edition with Nokia Software Updater. I did not think to test everything before flashing, but in hindsight, I should have. Anyway the screen is hanging a lot, every time I open an app and it goes blank for a second or two when I close some apps.
Another problem that is really annoying me is the fact that I take a picture on the camera. Then I go to gallery, where I have to wait for ages. There is just an icon, and it takes a very long time for teh captured image to appear.
Any ideas why this is happening? Anyone else with Music Edition? Should I try and Flash it back to regular N70 if possible? Any ideas would be helpful.
Wirelessly posted (NokiaN70-1/5.0616.2.0.3 Series60/2.8 Profile/MIDP-2.0 Configuration/CLDC-1.1)
slammin wrote:Hi,
to watch the photos you have taken from your n 70 go to gallary and then to cc files the photos will open at there now you can watch them at all files or in image & videos you should not have to wait
Sorry but i'm not entirely sure what 'going to cc files' is. Can you explain that bit please. Do you just mean to view in 'all files'? That does seem to speed up a bit, but still is slower than i would hope for.
I highly recommend you to use another program instead of the built in gallery. Search the forums (or with google) for a SW called CameraMagica and use it. It is freeware and works alot faster than the Nokia's gallery.
Well yes, i have used cameramagica and its quite poor, if anything i will use photorite. But the thing is there are no other apps to replace gallery for your recorded videos, are there?
