Quick method of changing ring volume
1 replies · 5,043 views · Started 09 January 2007
Dear All, I would like to set a shortcut to the volume control as one of the selection keys. This would save the trouble of going into profiles/options/peronalise/ringing voulume. However, there is no shortcut to volume control that I can find.
Just wondering if it was possible to set your own shortcuts rather than having to use those that are provided.
Thanks.
Jonathan
hmmm. It�s a setting and not an application. However this will shorten the task:
1. Menu->Tools->Settings->Phone->StandbyMode->Left Selection Key->(change to)Profiles->ok.
2. back back back back, you know standby mode :tongue:
3. Left selection key is now Profiles...->general->personilize.
Or:
1. Menu->Tools->Settings->Phone->StandbyMode->Active Standby->On
2. same place....Active standby apps. You can have now 6 different shortcuts that are displayed on your screen. Make one of them "profiles".
You know, that�s 13 shortcuts in total!!! (6 on screen +diagonals, selection, left and right selection)enough?
wondering why You have to change the volume? Do Your tones/tunes have so much different dB level?
I use freeware called MP3GAIN to make all my tunes same level, before transfering them to my 5500.
PS. If there is such cool app that can do better, I�ll let You know.
Greetz, VinterKrig 1939
